STM32 MCUs
From FAQs to complete How-to articles, find useful articles on STM32 MCUs programming, troubleshooting, ecosystem, and product details.
Knowledge base articles
How to configure the linked list mode in STM32CubeMX
Introduction This article provides a step-by-step guide on configuring the GPDMA linked list in STM32CubeMX. It does not cover the legacy standard DMA approach, which is described in the article "How to configure the GPDMA." 1. Software prerequisite...
Icache config.png GPDMA config(all channels).png GPDMA config(ch0).png linked_list_Queue_Config.png
Sarra.S by ST Employee
  • 10728 Views
  • 7 comments
  • 3 kudos
How can I add TraceX support in STM32CubeIDE?
To add TraceX support to a STM32CubeIDE project and properly use it you’ll need to follow a few steps, described in detail in this article. Goal: Add TraceX support to STM32CubeIDE using X-CUBE-AZRTOS-H7Although the example is using the NUCLEO-H723ZG...
How to use the STM32CubeMX2 Part Drivers and BSP
Summary This article guides you through using Part Drivers in STM32CubeMX2 (MX2), focusing on the Button and LED Part Drivers for the NUCLEO-C562RE board. You will learn how to enable, configure, and integrate these drivers into your project. This e...
BMontanari_0-1771014647162.png BMontanari_1-1771014647167.png BMontanari_2-1771014647172.png BMontanari_3-1771014647176.png
How to use EEPROM emulation with STM32CubeMX2
Summary This article explains how to use the STM32 EEPROM emulation driver on STM32C5 devices by leveraging a ready-to-build Visual Studio Code, CMake, and GCC example project. It introduces the STM32C5 EDATA FLASH sector and the main concepts behin...
BMontanari_0-1774361324173.png BMontanari_1-1774361324175.png BMontanari_2-1774361324178.png BMontanari_3-1774361324182.png
How to use the HAL2 structure and project format
Summary This article describes how to use the HAL2 project format when developing STM32 applications. It explains what changes with HAL2 compared to the HAL1 framework, how the new project structure affects user code, and how to work safely with cod...
BMontanari_0-1770812884384.png BMontanari_1-1770812884390.png BMontanari_2-1770812884394.png BMontanari_3-1770812884397.png
How to configure the MPU with STM32CubeMX2
Summary  This article provides a step-by-step guide to enable the memory protection unit (MPU) and configure a memory region in STM32CubeMX2. The example uses the NUCLEO-C562RE board. SummaryIntroduction1. Prerequisites2. Project setup2.1 Project c...
BMontanari_0-1769528501172.png BMontanari_1-1769528501176.png BMontanari_2-1769528501179.png BMontanari_3-1769528501184.png
CRC computation in STM32 MCUs and post-build creation
1. Introduction Cyclic Redundancy Check (CRC) is an error detection method for digital datas based on binary division.CRC algorithm generates a fixed checksum code length.  2. How is CRC value calculated, how to determine CRC algorithm in embedded ap...
How to use DAC with STM32CubeMX2
Summary This tutorial provides a step-by-step guide on how to enable and configure the digital-to-analog converter (DAC) peripheral using STM32CubeMX2. The example uses the NUCLEO-C562RE board and demonstrates output on DAC channel1. The tutorial cov...
BMontanari_0-1771439105018.png BMontanari_1-1771439105023.png BMontanari_2-1771439105028.png BMontanari_3-1771439105030.png
How to use RAM ECC on STM32C5
Introduction STM32C5 devices integrate a RAM configuration controller (RAMCFG) that provides error code correction (ECC) on internal SRAM. On STM32C5, ECC is available only on SRAM2. ECC allows the following: Detect and correct single-bit errors wit...
BMontanari_0-1770646689466.png BMontanari_1-1770646689469.png BMontanari_2-1770646689471.png BMontanari_3-1770646689474.png
How to use ADC with STM32CubeMX2
Summary This tutorial provides a step-by-step guide to enable and configure the analog-to-digital converter (ADC) peripheral using STM32CubeMX2. The example uses the NUCLEO-C562RE board and demonstrates the acquisition of two ADC channels simultaneou...
BMontanari_0-1770300899565.png BMontanari_1-1770300899568.png BMontanari_2-1770300899573.png BMontanari_3-1770300899576.png
How to use the MCO with STM32CubeMX2
Summary This article provides a step-by-step guide to configuring and verifying the master clock output (MCO) on an STM32 microcontroller. The workflow includes initial hardware configuration in STM32CubeMX2, project management using CMake, and proje...
BMontanari_0-1769541272670.png BMontanari_1-1769541272673.png BMontanari_2-1769541272676.png BMontanari_3-1769541272678.png
How to use FreeRTOS™ with STM32CubeMX2
Summary This article provides a step-by-step guide to developing FreeRTOS™ applications on STM32 microcontrollers using STM32CubeMX2 and Visual Studio Code. It covers configuring FreeRTOS™ within STM32CubeMX2, generating and building the project in V...
BMontanari_0-1770907837658.png BMontanari_1-1770907837661.png BMontanari_2-1770907837665.png BMontanari_3-1770907837668.png
How to use FDCAN and HSE with STM32CubeMX2
Summary This tutorial guides you through enabling and configuring the flexible data-rate controller area network (FDCAN) peripheral using STM32CubeMX2 on the NUCLEO-C562RE board. It includes: Setting up FDCAN for basic CAN communicationConfiguring cl...
BMontanari_0-1772672268492.png BMontanari_1-1772672268495.png BMontanari_2-1772672268498.png BMontanari_3-1772672268500.png
How to use RTC with STM32CubeMX2
Summary This article provides a step-by-step guide to configure the hardware real-time clock (RTC) with a basic calendar in STM32CubeMX2. The tutorial uses the NUCLEO-C562RE board. SummaryIntroductionPrerequisites1. Project setup1.1 Project creation...
BMontanari_0-1769630329893.png BMontanari_1-1769630329896.png BMontanari_2-1769630329899.png BMontanari_3-1769630329902.png
How to generate code for IAR from STM32CubeMX2
Summary This article provides a step-by-step guide on generating STM32 project code for IAR Embedded Workbench using the STM32CubeMX2 tool. It covers creating and configuring the project within STM32CubeMX2. This includes selecting the IAR toolchain,...
BMontanari_0-1771527298938.png BMontanari_1-1771527298942.png BMontanari_2-1771527298945.png BMontanari_3-1771527298948.png
How to change the color theme in STM32CubeMX2
Introduction To customize the interface for projects, use the options provided by STM32CubeMX2 to personalize the appearance of files. To change the default settings and apply a personal touch, follow the procedure below. Changing the color theme in...
BMontanari_0-1769615870047.png BMontanari_2-1769615870072.png BMontanari_5-1769616117482.png BMontanari_3-1769615870076.png
How to use DMA in normal mode with STM32CubeMX2
Summary This guide describes how to enable and configure DMA in memory-to-memory mode using STM32CubeMX2. The example uses the NUCLEO-C562RE board. SummaryIntroductionPrerequisites1. Project setup1.1 Project creation1.2 Enabling DMA1.3 Code generatio...
BMontanari_0-1769703285600.png BMontanari_1-1769703285603.png BMontanari_2-1769703285606.png BMontanari_3-1769703285608.png
