SW-DP ID code for G4 family incorrect in RM0440
Andreas Bolsch
Lead II
RM0440 states in 46.8.3 that SW-DP ID code is 0x1BA01477.
However, it's actually 0x2BA01477.
Imen.D
Hello @Andreas Bolsch​ ,
You are right. SW-DP ID code should be 0x2BA01477.
We will correct this typo in the coming release of RM0440.
Thanks for your contribution.
Best Regards,
Imen.
Imen
7 REPLIES 7
Imen.D
Best Regards,
Imen.
Imen
Imen.D
New release of RM0440 (Rev 4) is available with updates and fix of SW-DP ID code by 0x2BA01477.
Best Regards,
Imen
Imen
Thanks!
@Imen DAHMEN​ The web page says revision 4, but the document itself says rev 3, both in the footer of each page and in the revision history.
Thanks. I thought this was familiar (but obviously too lazy to search) 🙂
Uwe Bonnes
Principal III
As a DPv2 device, DP_TARGETID is also supposed to be there. On the G474 I have tested, DP_TARGETID is zero. That is a pity, making it harder for debuggers to early identify the device!
