2019-08-17 08:50 AM
RM0440 states in 46.8.3 that SW-DP ID code is 0x1BA01477.
However, it's actually 0x2BA01477.
2019-08-19 08:14 AM
Hello @Andreas Bolsch ,
You are right. SW-DP ID code should be 0x2BA01477.
We will correct this typo in the coming release of RM0440.
Thanks for your contribution.
Best Regards,
Imen.
2019-08-19 08:14 AM
Best Regards,
Imen.
2020-04-27 04:33 AM
New release of RM0440 (Rev 4) is available with updates and fix of SW-DP ID code by 0x2BA01477.
Best Regards,
Imen
2020-04-28 02:19 AM
Thanks!
2020-04-28 12:27 PM
@Imen DAHMEN The web page says revision 4, but the document itself says rev 3, both in the footer of each page and in the revision history.
2020-04-28 01:12 PM
2020-04-28 01:18 PM
Thanks. I thought this was familiar (but obviously too lazy to search) 🙂
2020-04-29 03:18 AM
As a DPv2 device, DP_TARGETID is also supposed to be there. On the G474 I have tested, DP_TARGETID is zero. That is a pity, making it harder for debuggers to early identify the device!
