ST25 NFC/RFID tags and readers
Ask questions and find answers on ST25 NFC/RFID tags and readers, including connectivity implementations and antenna design.
Resolved! ST25R3911B-AQFT label marking
Hello dear,We received a product of ST25R3911B-AQFT, it shows COO Thailand, but we check the PCN paper, the lable should be ST25R3911B-AQWT, but the actual lable is ST25R3911B-AQT, is it normal and correct? Thanks a lot.
tp_exp01 by Associate
  • 626 Views
  • 3 replies
Resolved! ST25R3916B Writing To Registers Bare Metal
For my setup, I am using a nucleo-L476RG and a NFC08A1.  I am wanting to learn bare metal programming to really grasp micro controller programming.  I have programmed some smaller bare metal programs, SPI, I2C, etc on the nucleo.  Now, I am trying to...
cbarb2747 by Associate III
  • 379 Views
  • 6 replies
Resolved! ST25R3918: Excess current in Power-Down mode with I2C_EN HIGH (I²C mode); resolved by switching to SPI
Hi ST team,We’re using the ST25R3918 in a low-power BLE+NFC product. During testing, we noticed unexpected ~10 µA additional current draw when the chip was in Power-Down mode (with all VDD rails active), despite expecting ~1–2 µA per the datasheet.Af...
BillR by Senior
  • 276 Views
Resolved! ST25R3917 Felica not Detect
Hello,I’m currently working on NFC detection using the ST25R3917 with Felica.My system configuration is as follows:PC Application ⇔ USB to I2C ⇔ ST25R3917I’m running RFAL in the PC application and have extended rfal_platform.c to control the USB to I...
tk_sorad by Associate II
  • 360 Views
  • 5 replies
Resolved! Layout Recommendations for ST3916 and ST3918
We are currently seeking layout recommendations for the ST25R3916 and ST25R3918 chips.On the Transmitter Side:ST25R3916B → Power Amplifier → Matching Circuit → AntennaOn the Reciever Side:Antenna → Matching Circuit →Power Harvester → ST25R3918The imp...
Resolved! Antenna Impedance measurement
Hello,I would like to confirm the correct procedure for measuring antenna impedance using a NanoVNA. The chip under test is the ST25R3916.I came across the post titled "How to Measure Antenna Parameters According to AN4974 with NanoVNA," which was ve...
