The data sheet contains the following TestCircuit:I wanted to use it to check the switch in PSPICE. Unfortunately I don't get the same results as in the datasheet. If my assumption is correct: Could you give me a TestCircuit for a PSPICE circuit wher...
Hi, I have to update my code in stm32f4 controller using esp8266. Is it possible to update the used code through online(OTA) can anyone provide me the information to how to do it. I have no idea about it while searching in web i could find that using...
This is an EEPROM.
Hi,I am using M34E04 I2C EEPROMread and write access works fine but I cannot enable write protection I have verified the WC pin is in the right state (logic 1) but I can still write to the device at this mode Any tip?RegardsAssaf
We are working on an IOT product for last 3 years. We were using other manufacturers EEPROM but then last year we switched to M24M02-A125, because of I2C interface and 4 million endurance cycle.But we are facing two problems with this EEPROM.1 - Ther...
I have Configured SPWF01SA21 in MiniAP Mode with WPA2 Security settings,but Not getting Up. Basically it is not showing "Crunching Key...." Message.Configuration is as follows.AT+S.WIFI=0AT&FAT&WAT+S.SSIDTXT=<my ssid>AT+S.SCFG=wifi_wpa_psk_text,<my k...
I'm trying to get a datasheet of PSD813F2A-90J in the following site, but I couldn't find the correct datasheet there.https://www.worldwayelec.com/pro/stmicroelectronics/psd813f2a-90j/5183742https://www.worldwayelec.com/pro/stmicroelectronics/psd813f...
Hello, Can you please suggest a drop-in replacement for the part: PSD4256G6V-10UI This seems to be a obsolete part.Thank you very much, Bijith
