RHOSC04 Input Question
Is it possible to drive this part using a single ended oscillator signal at 100MHz to IN2 and grounding IN1?
I have a photo with a label
Hi,We have found part VN750SMPTR-E which is almost pin to pin compatible with VN750PS-E . Except 4th Pin.4th Pin in VN750PS-E is - NC4th Pin in VN750SMPTR-E is - STAT_DISWhat is the use of the Pin STAT_DIS. Shall i left this pin as NC.Regards,Suriya
We can get the PTN which wrote the Last Order Entry Date 2021-04-01 and last delivery date 2021-10-01. Why we still can get the newer batch code CZ1480GK(2148+)?
