We are using below part in many of our application and requires more than 1000Qty. Part No - VN750PS-E / VN750PSTR-E currently stock is not available. Please suggest any alternate part. Regards, Suriya
Suriya R
4 REPLIES 4
Peter BENSCH
Maybe you can get the VN750SMP-E, which is almost pin2pin compatible (only pin 8 pin 4 differs).
Good luck
/Peter
Suriya R
Hi Peter,
Thanks for the reply.
unfortunately suggested part also currently not available.
Suriya R
Most places seem to suggest these are VN750PS-E obsolete, you only real path would be brokers, and doing whatever lifetime buy you're going to need
https://octopart.com/search?q=VN750PS-E&currency=USD&specs=0
Probably time to redesign
Suriya R
We have found part VN750SMPTR-E which is almost pin to pin compatible with VN750PS-E . Except 4th Pin.
4th Pin in VN750PS-E is - NC
4th Pin in VN750SMPTR-E is - STAT_DIS
What is the use of the Pin STAT_DIS. Shall i left this pin as NC.
Suriya
