could you tell me MTBF and FIT for part
could you tell me MTBF and FIT for part M24256-BFDW6TP,
I've just opened this issue on ST X-CUBE-EEPRMA1 github repo.All that commented lines sound suspicious to me.I'm not sure that the driver is production-ready, It seems an interanl work in progress.
Hi ST memberNow we use the M24512 of EEPROM but I can't find out the linux kernel driver ?Can you provide the linux kernel driver for me ?thank youJeffrey Tseng
Dear Support,Good day,Please advise what is the suffix KHA and KXA in the label for the part number M24M01-RMN6TP. Please refer to attached photo.Thanks
Hello, everyoneI currently have two ST semi-graphic chips that I would like to use in my retro projects. These are EF9345 and TS9347. I have the data sheets for both chips and an application note for the EF9345. Does anyone have any more information ...
Bonjour. Pour éviter de jeter je répare une alimentation Husqvarna .Un transistor de puissance J FET est HS Je ne trouve pas les références sur le marché. Voici les inscriptions y figurant de haut en bas. .Fabricant ST boitier TO220e3 g2LNM60NDG4065 ...
Edited by moderation, please do not share personal contact info in your question.
