Resolved! component eletronic
Please, i would like to know datasheet about this component. Someone could help me? because i need to change this component, and i can´t find it´s in my city.
Hi, Can anyone help please to identify what is this chip that hold the ST logo ? Here is the picture shows the chip. i searched a lot even on the digikey but i couldn't find anything.thanks
Good morning, I will try to be as concise as possible, I'm looking to change the location one of my GIT projects points to, I have a first software (STM32) where modifications have been made, and today I am looking to add a new project (STM32) to the...
Hello, I am writing some code to turn on an LED on my board through the IOExpander (STMPE811) but am facing some issues. I am able to read and write to I2C, and have done the following:written 1 to 0x10 (GPIO_SET_PIN) (Writing 1 to this bit causes th...
Previous I2C EEPROM chips had (eg) 3 address pins A2..A0, where you could hardware the I2C address. This allowed up to 8 devices on the same I2C bus in case you need more storage capacity.With the M24M01E this is no longer the case : the device can h...
Dear, I am looking for this component (diode) that I cannot identify to check its datasheet THANK YOU SO MUCHGREETINGS
M95M02-DRMN6TPMay I ask if there are any cases that cannot be EEPROM programming that can be shared?We are unable to EEPROM programming,thank you
Hi,Why is there no RAM block inside the Block diagram?In the document AN5747 (Page EEPROM memory architecture) there is a RAM block mentioned, but in the block diagram from the M95P32 datasheet no RAM block is available/visible.Thanks in advancenobod...
Hello everyone, I have a weird problem. At my internship, I was given a SIM900 and SIM7600 module and told to make projects based on them, yet I cannot find these modules anywhere on the internet. The project I wish to do with the SIM900 is thus: Sen...
您好M95M02-DRMN6TP 请问有 DEMO资料分享下吗这个物料 烧录不进 请问有没有案列分享下呢谢谢!
