2024-07-12 9:08 AM
Please, i would like to know datasheet about this component. Someone could help me? because i need to change this component, and i can´t find it´s in my city.
2024-07-12 9:48 AM
The type of marking does indeed suggest that it is a customised device to which and whose documentation only the respective customer has access, in your case Bosch. Unfortunately, only Bosch can help you - assuming they want to.
Good luck anyway!
/Peter
2024-07-12 9:27 AM
Looks to be a D2PAK-2 MOSFET
Perhaps custom manufactured, what brand / model of equipment is this in?
2024-07-12 9:36 AM
bosch drill speed control
2024-07-12 9:48 AM
Good luck anyway!
/Peter
2024-07-12 10:04 AM
Ok, I understand the situation, and polity of factory.
Thank you for information!
have nice weekend!
2024-07-12 10:28 AM
Yes, this would likely mean you'd need to cannibalise other boards for parts to replace this.
The voltages/currents involved might permit you to find an equivalent/over-spec'd device to replace or substitute.
2024-07-12 12:25 PM
Yes, i agree with you, i'll do it.
Thank you for information and your help!
have nice weekend!
