I'm trying to get a datasheet of PSD813F2A-90J in the following site, but I couldn't find the correct datasheet there.https://www.worldwayelec.com/pro/stmicroelectronics/psd813f2a-90j/5183742https://www.worldwayelec.com/pro/stmicroelectronics/psd813f...
Hello, Can you please suggest a drop-in replacement for the part: PSD4256G6V-10UI This seems to be a obsolete part.Thank you very much, Bijith
It is on a smart turbo trainer PCB and I need to replace it. any help would be much appreciated EEG3 729Andras
Hello, where could i find information about shelf life time for ESD protection HDMIULC6-4SC6Y with automotive grade?Thanks in advance for support!Best regards,
Hi,It's a problem is with device which is designed before 20years.Intro:· The MSP430F4250 is connected with M24C64(EEPROM through I2C) used to log 2 Byte date for every 6 second. This was working with no problems for 15 years.· Recently...
Hi,i know the world has advanced, everything Now is Arduino this, Arduino that... BUT... i feel curious about old technology... to learn about old technology.for example the Fujitsu MBM2732A eprom, UV erasable. 25v programmable.Newer/later versions w...
Hi,Has anyone been able to interface the current sense functionality with a 3.3V ADC?
