Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Resolved! STM8S003F3P6 all pwm use as simultaneously
STM8S003F3P6 in this there are two timer 1 with Four independent capture/compare channels (CAPCOM) configurable as input capture, output compare, PWM generation (edge and center aligned mode) and single pulse mode output and tim2 has 3 individually c...
Nikhil_ by Associate
  • 217 Views
  • 1 replies
EMIF06-HMC02F2 - Pinout configuration
Hi, In our schematic, the IC’s SD card pin is connected to the controller pin of the STM32H753VIH6, and the IC’s controller pin is connected to the SD card. Could this connection cause any issues during SD card read and write operations? I have attac...
Nandha by Associate
  • 201 Views
  • 1 kudos
Resolved! Windows 11 Driver for TYT MD-2017 DMR
I am trying to create a codeplug for my TYT MD-2017 handheld radio.  I have gotten to the point where the radio is listed in Device Manager under "Universal Serial Bus Devices" as "Digital Radio in USB mode" with no error icons.But when I attempt to ...
