2025-05-26 5:05 AM
I found that the TDA7786 provides a datasheet, but based on others' code, it seems to lack a lot of content. Are there any similar technical reference documents or application manuals? I feel like I can't write the driver based solely on the datasheet.
2025-05-26 6:27 AM
The TDA7786 is an automotive device whose tools and support are usually only available from your local distributor or STMicroelectronics office.
Hope that helps?
/Peter
2025-05-26 6:27 AM
Hope that helps?
/Peter
