Others: hardware and software
M95P32 page write behaviour
Hi,Why is the page-write consuming less power then a page-program? When I understand it correctly then the page-write, is first erasing the page and then writes the values back. So then the page-write power consumption should be similar to erase and ...
nobody by Associate II
  • 355 Views
  • 0 replies
Z85C30 SDLC Communitcation issue
I am setting up SDLC communication using the Z85C30 chip. However, when I enable Tx and send data, it appears that the data is mixed with 7E. After the Tx is finished, I disable it. Is there a way to ensure that 7E appears only at the start and end?
Dlak by Associate II
  • 542 Views
  • 3 replies
Learning materials to improve the code
I'm Intermediate in Embedded C and I need to improve my code's readability, safety, scalability and portability with designing a software architecture. Can someone suggest good learning materials (books or courses) where I can learn these.
jsw2000 by Associate II
  • 394 Views
  • 0 replies
EEPROM - M24M01E-FMN6TP
Hi, We have made a custom development board integrated with M24M01E-FMN6TP EEPROM IC. It is operating at 1.8. Having queries like whether the supply voltage plays a role in accessing total pages of EEPROM and if so please tell us the minimum voltage ...
Resolved! Failure rate (FIT) of BAT30SWFILM
Hello,Can someone provide me the failure rate (fit) of this Schottky diode? I'm updating our database and couldn't find this information on any datasheet / report.PN:  BAT30SWFILMIf the number isn't available could someone provide a guide of how to c...
STUSB4500QTR Stops working
Hi, I am trying to use STUSB4500QTR in a new board. In my design, the STUSB4500QTR is supplied from a USB-C power adaptor. The application intended for use of 20V supply. When connecting the adapter to USB-C port for first time, there is 20V on outpu...
Ner by Associate II
  • 1153 Views
  • 5 replies
