Specs for EXTVCO_IN for STW81200
mallets
Both STuW81300 and STW81200 have the option of using an external VCO but the inputs characteristics aren't specified anywhere. What is the input frequency range, input power/sensitivity in dBm or 50ohm match for single-ended input? There is one application diagram showing VCO output with a coupling capacitor followed by a balun. Can we just ac ground the other pin instead of a balun?
0 REPLIES 0
