Resolved! STHV1600L datasheet ?
i couldn't find the datasheet here. Does anyone have the datasheet for this part# STHV1600L? or STHV1600?
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
HI Sir / Madam, Is there any documents support for the soldering Reflow temp. ofTS55IDTTR, reflow soldering profile or curve chart? THanks. Best Regard, Victor Lai
I am looking for an EEPROM device that has the UID but also supports the 256-byte identification page.I was lead to believe that densities less than 1M support either/or, but greaterthan/equal to 1M does support both.However, from what I can tell fro...
Regarding the Schottky diode 1N5711, could you please tell me what the reverse resistance value of this diode is? Our factory's designer believes that the reverse resistance value of this diode can be greater than 200 megohms. Could you please confir...
Hi, Can I use lis3mdl as gyroscope as I observe this behaviour while reading it's raw values.Thanks
Hi everyone, I saw that ST give a C driver for STUSB4500 and even have a binary to test the 4531 on some boards.Can ST provide a C library for this chip ? Thanks.
Hi all, Quick question for those working with STM32 embedded devices: If you had a tool that could analyze logs or telemetry using AI — would you feel comfortable sending that data externally? Or is data sensitivity (customer data, device behavior, i...
Hi,We are using the ST Micro Devices SLVU2.8‑8A1 TVS array on the primary side of the Ethernet connector for ESD protection in a 1000BASE‑T Ethernet design.It is observed that when the SLVU2.8‑8A1 is mounted, the 1G Ethernet link reports FCS errors w...
I'm designing a USB-C charging circuit for a battery-powered device using the STUSB4531 for PD negotiation alongside a BQ25792 buck-boost battery charger. The BQ25792 handles the full VBUS power path internally (inrush limiting, reverse current prote...
Hi everyone,I'm currently working on a project involving a stepper motor controlled by an STM32 microcontroller, and I wanted to share a quick overview of how I set it up using STM32CubeMX.Hardware:STM32F103C8T6 (Blue Pill)Stepper Motor (28BYJ-48)Ste...
