Alternates for obsolete ESDA6V1S3
Posted on August 03, 2017 at 12:11Hi,The ST part ESDA6V1S3 is now obsolete. I need alternate for this Does anyone have any suggestions for a part that might be a suitable replacement...?
Posted on August 01, 2017 at 15:31Hello, I have a FET from ST which I cannot find a datasheet. It is labled as follow: 19NMSONG40TD V6CHN 236 Can you provide me with a datasheet or a correct type name? Thank you!
Posted on July 28, 2017 at 17:50 Hello, I'm trying to simulate STP55NF You can download its model here: http://www.st.com/en/power-transistors/stp55nfhtml. The pin 1,2, and 3 should be gate, drain, and source respectively. I connected a circ...
Posted on July 13, 2017 at 09:27Hello, I'm looking for the datasheet of the SCR 'JS2617'. Could anyone help me ? Thanks.
Posted on July 11, 2017 at 12:56As per data sheet of LM339, the input voltage range is from -0.3V to 36V. We are using LM339 as a Comparator in our circuit , in certain cases, we have a voltage of -0.7V at Vin ( inverting). which is above the specif...
Posted on July 07, 2017 at 10:09Hello! When NAND02GW3B2CN6E had been discontinued? Thanks
Posted on July 06, 2017 at 10:10 During development of a driver for ISP1763a usb device (gadget) under Linux OS, I had some difficulties, which I hope you will help us solve. The driver ISP1763a works on the NOR interface in asynchronous multiplex...
Posted on July 02, 2017 at 15:18Where can I find documentation about ST L9101 chip? I found this part in motorcycle ECU. I have to check it.
Posted on November 15, 2016 at 16:26Does anyone have it to share? I would like to test. Theres no eval version on pls website.
Posted on January 24, 2015 at 12:32I want to know how to programm st10f273 in boot strap mode ,can anyone provide the procedure and connection diagram of the circuit?
