M24C08 NC pins
Hi,Because of my PCB design, the NC pins of M24C08 eeprom are connected to GND. Would this cause any problem ? Any advise ?
Testing some old transistors for a customer and parts are marked with a FB ending. These are 1997 parts . Anyone know what that calls out? Is it factory burn in? also can't find a ST datasheet for these if anyone has one LMK.
We are making ultra low power device, which has function to read change of state on pin. For better understanding please refer the attached photo. Well, in Case 1 we get pulse on the pin as wheel is rotating and it's fine to read. But the problem is ...
Hi,I have a weird issue !I am developing an application where i Use the M24C64-WDW6TP EEPROM.First I need to be sure, this eeprom have 8KB of memory, every page is 32B so it has 256 pages.is the page address = (page number - 1 )*page_size ?? for exam...
Hi allwe are using a custom PCB with the STHV800 IC on it, in the past we've used it primarily as a pulser IC, not yet to take the reading signal into account. Now that we want to take a look at the echo, we don't see the expected echo when comparing...
"M27C256B-10F1"�?�該�?�判定書を頂�?�る�?��?�ょ�?��?�。購入先�?�商社�?�廃業�?��?��?��?��?�り�?購入実勢�?��?��?�商社�?��?��?該�?�判定書�?�発行を対応�?��?�もら�?��?��?�ん。宜�?��??�?�願�?��?��?��?��?��?�。
The EEPROM M95512-D has an identification page that could be write protected permanently. In teh datashett is the address of this page not mentioned. I need to know the address for the identification page.
Can this, or another, hysteresis circuit work with LM239?LM239 datasheet doesn't mention hysteresis.https://www.digikey.com/product-detail/en/stmicroelectronics/LM239DT/497-2973-1-ND/634871
Please help me. I need data sheet for the attached module. Any suggestions for possible replacement?I appreciate any input
