Resolved! what is part number for SMD marking GB4 diode?
Hello,I need exact part number for smd diode GB4 or maybe G84, which I have attached the image.Thanks.
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
I'm looking to program a ST92F150 chip and I cannot find any ST9-EPB for sale.I understand this MCU is obsolete now thus toolchain is not available anymore.However, do you know if there is a way to program it using a newer model of programmer ? Or, ...
HiI want to connect the VL53L1X-SATEL to ESP32 (3.3v) via I2c interface, but I cannot find the pins on the datasheet. The datasheet shows a J1 block of 10 pins but not sure where the locations of SCL, SDA, GND, VCC. One more question, does VL53L1X-SA...
Dear community members,We have an STUW81300 EVB that we control from the PC GUI, and we want to know at which pace the the PLL switches from frequency to frequency in the course of the frequency plan replay (Freq Plan pannel in the GUI).I read UM2218...
Hello every ones; i found this component from ST: 211 ST- EZ204.Is a four pin Integrated circuit. does anyone know what it is? I cant found it data scheet
Hello.I am trying to install the program but it gives an error. I can't get past step 7. In step 7, the quit option appears. I tried it on 5 different computers. always the same error. what could be the reason for this? Please help me.
Hello, I can not login to ST website. I was trying to download the Unicleo-GUI. Each time I try, when I press on the "user" icon from the main st.com page, a "bad gateway" error message is shown. In the past I was able to login. EDIT: A day after...
In the HVLED101 design tool, there is the option for a custom transformer. When selecting the core type it seems possible to add a new core type (component) for a transformer design. When adding one, a screen pops up that says "Please, compile the fo...
Hi, Could you provide me the MTBF or FIT value of M24C02-FDW6TP.
Hi,I am planning to use STM32 bluepill board with Freertos. Hence trying to use Freertos API. I wanted to know how the CUBE IDE makes sure that API call to Freertos doesn't transform into an API call to Linux OS on which CUBE IDE is installed during ...
