Automotive MCUs
Ask questions and find answers on automotive microcontrollers like the SPC58 and their tools, such as the SPC5 Studio and how to implement JTAG unlocking.
Resolved! How to install your Root Certificate in StellarStudio JRE
When installing some StellarStudio  plugins http://*.srxstudio.org , you can meet the issue : sun.security.validator.ValidatorException: PKIX path building failed  It is typical IT Issue :face_screaming_in_fear:  in each corporate company. “"Path bui...
StellarStudio SR5E1 support is open to the mass market !
Dear all,   We are thrilled to announce that as of today, March 1st, 2024, SR5E1 device support in StellarStudio is available to the mass market !   This means that any user can effortlessly download the official StellarStudio installation packag...
SPC5 and L9907 current budget recommended?
Hello!I am developing a motor controller driver running on a 48V Li-Ion battery. I want to choose the right regulators. Unfortunately I can not use the MCTK-01 as reference because it is supplied via the mains.What is the current budget I should plan...
CTara by Associate II
  • 1047 Views
  • 1 replies
Need help in CAN driver development for spc58xx series
Hello expert, I have just started working on Eiger controller and wanted to develop CAN driver for spc58xx series controller. I do have referrence manual but this device seems to be more complex than others. do you guys have any other technical docum...
vchav.17 by Associate
  • 1147 Views
  • 1 replies
Unable to install Flash Driver
Hello, I did a fresh install of SPC5Studio 5.8 and I'm trying to install the Flash Driver from Eclipse Marketplace.But all I get is a:No repository found at http://spc5.drive.cloudforge.com/projects/spc5releases/SPC5Studio/updates5.I also tried to lo...
SPC58 flash and debugging tool
Hello experts,Can SPC5-FLASH and SPC5-UDE be used on SPC58 series MCUs? For example, can the SPC-UDEDEBG tool quoted here be used for SPC58 boards other than the Discovery kit?https://www.st.com/en/development-tools/spc5-udedebg.html I am looking for...
YC by Associate
  • 1711 Views
  • 1 replies
SPC560B jtag debugging
Hello friendsI am working on a SPC560B50L5 microcontroller and I want to learn debugging it.According to"AN4035 Application note" I can do a single step by loading appropriate values in CPUSCR registers. I do everything that is mentioned in Document....
sdrad by Associate II
  • 885 Views
  • 0 replies
Stuck in SPCSetRunMode() when debugger is attached.
Using the PLS USB/JTAG probe on a SPC56EL, I'm unable to debug because I'm stuck into SPCSetRunMode(). Unplugging the probe, and resetting the MCU make the FreeRTOS demo run nicely. I'm aware of some errata about low-power issues, but I'm not sure th...
nono240 by Associate II
  • 771 Views
  • 0 replies
