CubeMX hides "SMPS enable" too well for users of STM32U5
BarryWhit
Senior III
Cube is very enthusiastic about reminding you to enable the SMPS on U5 chips
And it's also infuriatingly coy about how one actually does this:
Here is just the latest example of an understandably confused costumer.
I would like to see the warning message amended to give more specific instructions on how to do this,
(i.e. "enable low-power/power saving mode and then choose SMPS as the power regulator")
and the PWR pane should be modified to be more self-explanatory, either by reworking the options,
or the help strings, or both.
- If a post has answered your question, please acknowledge the help you received by clicking "Accept as Solution".
- Once you've solved your issue, please consider posting a summary of any additional details you've learned. Your new knowledge may help others in the future.
BarryWhit
Senior III
Also, I believe this is a known bug but if it isn't it should be fixed - Cube should not issue a warning abouse enabling the SMPS for part numbers that don't have an SMPS (obviously).
cc @STTwo-32 .
BarryWhit
Senior III
For future victims visitors:
Isn't that just terrible? as the only way to resolve a warning message every customer who starts a cube project for STM32U5 sees? it really is, it's terrible.
