ST25 NFC/RFID tags and readers
Ask questions and find answers on ST25 NFC/RFID tags and readers, including connectivity implementations and antenna design.
Resolved! How to start with ST25R3911B and is It really necessary to use rfal and st25r3911 libraries for simpel project?
Hello everybody!In my company We decided to use ST brand for our "NFC projects". Anyway, now I have Nucleo board 32f070RB and x-nucleo-NFC05a1 with ST25R3911B chip.For now We have a simple project, just to read and write to/from the Tag (some of the ...
DIvan.1 by Associate III
  • 6244 Views
  • 39 replies
  • 1 kudos
Resolved! ST25R3916 CSI and CSO pins
Hi,I don't want to use the ST25R3916 capacitive card detection that involves CSI and CSO pins. Can I leave this pins unconnected? What part of rfal should I remove to do this?Thanks in advance,gaston
Gaston by Senior
  • 739 Views
  • 1 replies
Resolved! ST25R3916-EMVCO
Hi,Where's the ST25R3916-EMVCO documentation? Schematics, BOM, gebers, User Manual.It is an available product? I'm not able to order it through any distributor.regards,gaston
Gaston by Senior
  • 490 Views
  • 1 replies
Resolved! Having issues with the ST25R3916
ST25R3916 is having issues, pointing to a layout issue but hoping for some insight also on the schematic (both attached). Have broken our board out and running the ST25R dev kit via SPI with our STM32 no problem pointing to issues with the ST25R. Pur...
CBerr.2 by Associate
  • 1512 Views
Resolved! ST25RU3993-eval PCB Internal amplifier output differential traces don't look right for preferred impedance.
ST25RU3993-eval PCB Internal amplifier output differential traces don't look right for preferred impedance. See the traces circled in red. Shouldn't these be 100 ohm differential the same as the purple mixer feedback traces? The trace width in the...
DBurt.1 by Associate II
  • 1483 Views
  • 7 replies
Resolved! Dear all, which simple methode is suggest to identify if the ST25DV04kxxx has powered the STM32Lxxx?
Basically we have follwing problem: We have an App which reads out the ST25DV04K, behind we have STM32L011xxx which makes some calculations as well and the result is stored in the ST25DV04Kxxx. However sometimes the NFC field is not strong enough and...
CLemb.1 by Associate
  • 473 Views
  • 1 replies
  • 1 kudos
