2020-10-06 01:05 AM
Dear Sirs
In the ST25R3911B_DISCO_FW_v1_2_8 code, the iso15693Inventory function does not response RSSI data. But in the Middleware i find a rfalGetTransceiveRSSI function that can read out the RSSI data. Could you please how to use rfalGetTransceiveRSSI function during ISO15693 inventory? Thank you.
Best regards,
Phil Huang
2020-10-06 03:15 AM
Hi Phil,
the upper functions are not ready to transport the RSSI for every transceived frame to the upper layers. Here you will need adapt/write your own versions of iso15693Inventory()/rfalNfcvCollisionResolution() function to retrieve this information.
Alternatively you can also retrieve that information as a separate step after the inventory by sending a new command to each of the identified cards like e.g. READ_BLOCK or GET_SYSTEM_INFORMATION an then use rfalGetTransceiveRSSI().
Regards, Ulysses
2020-10-06 03:15 AM
Hi Phil,
Regards, Ulysses
