Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Resolved! Default I2C address of ST33KTPM2X
Hi, In the ST33KTPM2X datasheet is mentioned that the I2C device address is configurable in the range of 0x08 to 0x77, but what is its default after power-up ... it is not mentioned in the datasheet. A STSafe application note suggests 0x2E, is that c...
LMaarsen by Associate
  • 848 Views
Doubt flash memory Nor retention
NOR flash memory chips behave the same as other types of flash memory. If I energize NOR flash once a year, will it prevent any data loss? The datasheet says retention 20 years. If I energize it after 19 years, will it prolong data retention?in my ca...
ÍStef.1 by Associate II
  • 4640 Views
  • 9 replies
  • 1 kudos
VNLD5160
Hi at all.Can VNLD5160 work with a normal STM32 CPU with 3.3V logical levels?I don't find this information in datasheet...Thanks...
bestyeng by Associate II
  • 1839 Views
  • 1 replies
  • 2 kudos
Regulator
Bonjour à tous voilà j'ai un transistor défectueux sur une carte electronique et je n'arrive pas à trouver son équivalent.Sur le transistor il y a inscrit GPLONC6OKD GKLKE V6 CHN 907je vous joint une photo du composant  Merci à tous cordialement 
