CAN bit timing parameters for 125Kbps @ PCLK=48MHz
Posted on July 19, 2008 at 09:42CAN bit timing parameters for 125Kbps @ PCLK=48MHz
Posted on July 18, 2008 at 08:41SRAM access
Posted on July 21, 2008 at 02:45where is CP15 (buffered/un buffered)
Posted on July 16, 2008 at 14:24no embedded loader inside STR9 and STR7 , right?
Posted on July 18, 2008 at 17:00Configuration is changed after system wakes up from Idle mode
Posted on July 15, 2008 at 11:32Fiber Optic Ethernet
Posted on July 18, 2008 at 10:14error in the STR9 library?..............91x_emi.c
Posted on July 08, 2008 at 20:25STR912FA (IAR Eval board) - Help on Startup files
Posted on July 21, 2008 at 07:22I2C Slave clock
Posted on July 07, 2008 at 20:09External RAM Interface
