Problem WNRO (week number roll over) in GPS chipset STA8058
Since April 6, 2019 does not work, does anyone know how to solve it?Thanks,Jorge.
I see that ST2100 is active but it seems there is no stock in anywhere.I only see datasheet but, are there more documentation, application note, evaluation board for this broadband PLC Soc?Thanks in advance!.Best regards.Francisco Jimenez.
Hello, I've downloaded the provided .lib file for p/n STD13N60M2 and created a part for it in LTSpice, but am not having any luck getting it to work correctly. I've created a circuit with a half bridge and get the expected results when using the mode...
Hello,I currently work with an STM32L496ZG chip and the EEPROM emulation driver (download on https://www.st.com/en/embedded-software/x-cube-eeprom.html).In the "eeprom_emul.h" file, we have the next macro :#define PAGE_ADDRESS(__PAGE__) (uint32_t)(...
Hi, I use CLT01-38SQ7. In datasheet (DocID028182 Rev 1) is not clear to me how to use Vcs pin (24V sensor power supply sensing input) for UVA purpose.In Figure 7. “Logic status of the SCLT3-8BQ7 power supply�? voltage ranges of Vcc and Vc are shown, ...
We are using USBUF01W6 as EMI filter for STM32F207VCT6 in USB D+ and D- lines in Full speed mode and we have connected VBUS (5V) at pin 3.3V pin of USBUF01W6. Does this make sense to you?NOTE: This question and answer originated from a customer suppo...
I have to read this ARM926 by JTAG connections but I don't have MCU pinout. On web I can only find a datasheet without pinout description.
Hello...Is the STG3157 suitable for headphone-level audio? I need to switch between the inputs of two microphones and put one of them into a small audio amp IC.Thanks!--Jim Newton
