Imaging (sensors)
Discuss applications using ST FlightSense Time-of-Flight sensors, ST BrightSense CMOS image sensors, and ambiant light sensors (ALS) technology. Find answers to your questions on troubleshooting, data accuracy, optimizing communication and more.
VL53L8CH raw data
Hello,We want to do an experiment for smoke detection with ST's ToF technology. We are using the following STM products:    - VL53L8CH    - x-Nucleo-53l7a1     - STSW-IMG043The GUI has so many configurations and it provides raw data and algorithm out...
aroshani by Associate III
  • 3829 Views
  • 7 replies
  • 4 kudos
Resolved! Light Characterization for VL53L8CH VCSEL
Hello,I am trying to do some ray tracing simulation for your VL53L8CH in a specific environment. I was wondering if you have any data beyond the "Field of Illumination" diagram for your VCSEL emitter (I assume you make your own emitters in-house). An...
JGarrettW by Associate II
  • 3420 Views
  • 6 replies
  • 3 kudos
VD6283_GUI application not starting on Windows
Hello,   I'm trying to use the VD6283 sensor on a X-NUCLEO-6283A1 plugged in a Nucleo-64 STM32F401.   For this, I've installed the latest ST-Link drivers and the software STSW-IMG301. My board is well recognized on Windows device manager as a "STM ST...
VL53L1X in humid and pressurised environments
Hello, i want to use the VL53L1X, or equal TOF sensor in humid and pressurised environments. First Prototypen are potted into Epoxyd-Resin.  I also want to try parylene coating, because of hydrophob surface.  For that reason I want to ask, if anyone ...
MIKE_94 by Associate
  • 1257 Views
  • 0 replies
  • 1 kudos
IMG043_EVK Configuration issue on VL53L7CH
I am using the IMG403 EVK GUI to test and validate the module VL53L7CH in a product. I am facing a few issues in the GUI. While trying to plot the histogram in "Zone 8x8" mode, I am getting an error. Similarly, if I change the configuration "MZ-AI Co...
Resolved! Unable to read ID Register directly
Hello,  As suggested in my last post here, I am trying to read the ID Value of a VL53L1X sensor. I get a read failure when I attempt to read the register. Strangely, I have slightly modified code that I am using to read the ID register of a VL53l0X w...
mttdarko by Associate II
  • 2473 Views
  • 5 replies
  • 1 kudos
Resolved! Selecting ST ToF Modules for Distance Measurement During Free Fall
Hello community, I am working on a project that involves measuring a precise distance of 2 meters from the ground during an object’s free fall. I am considering using Time-of-Flight (ToF) modules from ST for this purpose and would like some guidance ...
Vect by Associate
  • 1372 Views
  • 1 replies
  • 1 kudos
Resolved! VL6180X laser compliance documents
Hello,We are using the VL6180X in a IVD product and need laser test certificate documents to show the range sensor is class 1 and safe for the user. Can you send me a test reports for this part? I see a CDRH report posted for VL53L1, but couldn't fin...
AJB721 by Associate
  • 1348 Views
  • 1 replies
