Imaging (sensors)
Discuss applications using ST FlightSense Time-of-Flight sensors, ST BrightSense CMOS image sensors, and ambiant light sensors (ALS) technology. Find answers to your questions on troubleshooting, data accuracy, optimizing communication and more.
Resolved! Please check my observations about AN5894
Are formulas 1-4 correct in AN5894?Segment [AC] is the hypotenuse of triangle ACE, and the angle between segments [AC] and [CE] is half the dihedral angle HFOV. Then formula 1 should have a sine instead of a tangent.If I am right, in the example the ...
TGrod by Associate II
  • 4579 Views
  • 9 replies
Resolved! VL53L8CA Data Sheet & Sample
Hello,VL53L8CA is active product on your product list but i couldn't find a datasheet and sample.I have contacted with my local reseller buying termin is 22 weeks. Before buying i would like to have a datasheet and sample. What is the last situation ...
Tamer by Associate II
  • 6033 Views
  • 10 replies
Resolved! VL53L8xx SPI & daisy-chain support
Hi!I’d like to know if the Vl53L8xx product series support “SPI daisy-chaining” ?For a project, I’ll need few of those, either “straight” along a line segment ( +/- like Neonode’s ZForce sensor bar ), as a “grid”, or as an “arc section” ( that is, a ...
Resolved! VL53L4CX meaning of CalibrationData
Hi,I would like to know the meaning of each data in the L4CX calibration data(VL53LX_CalibrationData_t in API), because there is a lot of data for this IC, and I would like to confirm the status of the calibration from the data.Thank you.
YChen.9 by Associate II
  • 2329 Views
  • 3 replies
  • 1 kudos
SATEL-VL53L8 + ESP32 => VL53L8CX ULD Loading failed
Hello everybody,I have connected a SATEL-VL53L8 board to my ESP32, and I am trying to run the basic ranging example, using ULD driver. When I run the example, I get VL53L8CX ULD Loading failed in the serial terminal. Trying to figure out what's wrong...
milukic_0-1708538107965.png milukic_1-1708538789889.png milukic_2-1708540300044.png
milukic by Associate II
  • 3529 Views
  • 5 replies
Resolved! vl53l1cb: how to get the maximum distance
hello, I'm using a vl53l1cb satel board, but I'm not been able to get a reading greater than 4m (aprox).I'm using the vl53l1 zephyr RTOS driver, and I'm aware that the roi selection is different than the one of the UM2133, so I'm not selecting a spec...
VL53L8CH raw data
Hello,We want to do an experiment for smoke detection with ST's ToF technology. We are using the following STM products:    - VL53L8CH    - x-Nucleo-53l7a1     - STSW-IMG043The GUI has so many configurations and it provides raw data and algorithm out...
aroshani by Associate III
  • 3798 Views
  • 7 replies
  • 4 kudos
