Edge AI
Ask questions and find answers on how to deploy, debug, and optimize AI models on ST microcontrollers, microprocessors, and smart sensors.
Resolved! Edge AI
How to check the classification accuracy of image classification models on STM32H7 ?    Ritesh
Ritesh1 by Associate II
  • 1304 Views
  • 1 replies
X-CUBE-AI issue with other peripherals hanging
Hi everyone,I'm currently working on a project that involves implementing Edge AI using the X-CUBE-AI software package within STM32CubeIDE. After adding the AI model, which requires 44 bytes of RAM and generating the necessary code, We encountered a ...
Jf1_0-1729000361058.png Jf1_1-1729000500742.png Jf1_2-1729001567252.png Jf1_3-1729002352052.png
Jf.1 by Associate II
  • 1217 Views
Resolved! NanoEdge AI Studio usage
Dear Support As I am trying to get familiar with the NAnoEdge AI Sudio, I tried the followed steps to setup a demo project:1. New project -> select the EVB(NUCLEO-F401RE) and Sensor(Accelerometer - 3 Axes)2. Regular Signals : Create a datalogger -> S...
XiaoKang by Associate
  • 7785 Views
  • 1 kudos
Resolved! modelzoo deployment error
i need some assistance with modelzoo . so first of all . i converted a dataset to darknet using converter.py than i trained it using train mode i had a 2.6mo  .h5 file  then i quatized it to 600kb .tflite file. but when i tried to deploy it i had an ...
yessine by Associate III
  • 2166 Views
  • 3 replies
Resolved! use B-L475E-IOT01A2 for data acquisition for training with NANOEDGE AI STUDIO.
私はNANOEDGE AI STUDIO内のData Logger Generatorを参照しました。現在ここに私が所有するB-L475E-IOT01A2(開発ボード)がありません。そこでB-L475E-IOT01A2で温度・湿度・加速度のデータ・ログを取得し、NANOEDGE AI STUDIOにて機械学習を実行したいと思っています。なお温度は内部温度センサを使おうと思います。そこでB-L475E-IOT01A2で使えるおすすめの湿度センサ・加速度センサを教えてください。また、内部温度センサ・...
Resolved! INTERNAL ERROR: Value of zero not correct
Hello, everyone! I'm learning to deploy my target detection model using cubeai. My model is trained using pytorch and I found that cubeai doesn't support .pth file conversion so I'm trying to convert my model to onnx format. Since the size of my mode...
ST NanoEdgeAI data constraints
Hi, I was working with NEAI and saw these constraints mentioned in the wiki:General considerations for input file format:.txt / .csv filesNumerical values only, no headersUniform separators (single space, tab, comma, or semicolon)Decimal values forma...
