code generation fail with FreeRTOS in Trustzone at STM32L5
JongOk Baek
I want to generation code with FreeRTOS in Trustzone at STM32L562ZET6Q.
I want to use FreeRTOS in Non-Secure Zone.
So, I enabled FreeRTOS in Middleware division.
0693W00000WKMW2QAP.pngAnd, I want to change about Timebase Source in SYS_NS.
0693W00000WKMVnQAP.pngBut, all timers are disabled(inActive) except SysTick.
0693W00000WKMY3QAP.pngSo, there occur warning message about SysTick when run code generation.
Environments :
STM32CubeIDE : v1.11.0
STM32CubeL5 : v1.5.0
Best regards.
KDJEM.1
Hello @JongOk Baek​,
You can change the Timebase source in SYS_NS by enabling the dedicated timer as shown in the below figures.
 I advise you to get inspired from the available freeRTOS examples in the STM32CubeL5 MCU package.
Thank you.
Kaouthar
3 REPLIES 3
KDJEM.1
Thank you.
Kaouthar
Thanks for your reply.
It is correct answer.
My problem has been solved.
KDJEM.1
Hi @JongOk Baek​,
Glad to know that the issue is solved.
Thank you for your contribution in the STCommunity :).
Kaouthar
