2020-07-27 01:49 PM
Hello!
I found a bug with the Nucleo STM32 F401RE + FreeRTOS + STM32CubeMX 1.4.0. It gives hardfault error. I have posted all information here:
https://electronics.stackexchange.com/questions/512612/hardfault-with-freertos-at-stm32-new-project
Thank you.
2020-07-29 02:46 AM
Hello @Daniel Mårtensson
Thanks for the feedback, issue reported to the tool development team that will plan the correction.
Best regards,
Nesrine
2020-07-27 10:56 PM
2020-07-28 03:06 AM
Tested the same scenario by using the last version of STM32CubeIDE (V 1.4.0), i had no issue.
Please try with this version then tell me the result,
Best regards,
Nesrine
2020-07-28 03:12 AM
Hi! I tested with 1.4.0. Did not work.
I'm using Linux Generic Installer on Lubuntu 20.04.
Look above. Somebody posted an issue.
2020-07-28 05:14 AM
@Nesrine.JLASSI I confirm @Daniel Mårtensson issue using NUCLEO-F401RE board.
Relying on NUCLEO-F413ZH all is fine ...
@Nesrine.JLASSI have you picked the right board ?
Working myself on Win10
2020-07-29 02:46 AM
Best regards,
Nesrine
2020-07-29 03:14 AM
2020-07-30 08:02 AM
A new STM32CubeMX release will delivered to correct this issue as soon as possible.
Best regards,
Nesrine
2020-08-13 12:13 AM
I have worked on Win10, STM32CubeIDE Ver. 1.4 , and Nucleo-F401.
It is very strange to see this HardFault_Handler() error over PC in office but PC in home. Of course, I have used same version of STM32CubeIDE in two places. From a few days ago, it has made a HardFault error in office PC. I can see this error whenever I used FreeRTOS only, and I have no problem if I did not use FreeRTOS.
Best regards,
Jongwoon
2020-08-13 12:29 AM
Hello @JChoi.4
Yes! the problem appears only when you activate FreeRTOS.
Best regards,
Nesrine
