STM32H7 LSE Hardfault
‎2023-04-17 3:29 PM
I'm using external crystal for RTC on STM32H750VB. Sometimes when i powered up to board, its hanging on LSE initialization and entering hard fault. If i remove rtc backup battery and plug it again, its working. This happens very rarely :S I couldn't find where the problem originated.
DEBUG
RTC
STM32H7 Series
‎2023-04-17 4:46 PM
Isn't the hardfault consequence of badly handled timeout? LSE may take surprisingly long to start up, 10 seconds is not an unlikely time.
‎2023-04-18 12:37 AM
Yes, it's true. But it's not releated to crystal. I mean, when this situation happen i can power up/down board a lot of times and LSE always fail. But if i remove RTC Backup battery and plug it again LSE surprisingly decide to work. I couldn't find the relationship between RTC backup battery and LSE?
‎2023-04-18 1:35 AM
LSE is powered from VBAT. Review supply voltage domains description in datasheet.
If LSE is prone to failure, you should try setting different LSE drive strength in RCC_BDTR, or review the whole LSE circuit design, read AN2867. You may want to start with a "known good" board such as Nucleo or Disco.
‎2023-04-18 2:03 AM
Yes it's true if you have not powered board. But i think i understand the problem now. When rtc backup battery attached, lse always powered on and if it stops working the only way to reset to lse is remove backup battery.
I have already tried low/medium/high LSE drive capability.
Thanks for reply.
