M95M02-DRMN6TP
您好M95M02-DRMN6TP 请问有 DEMO资料分享下吗这个物料 烧录不进 请问有没有案列分享下呢谢谢!
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
the chip of ST is different from traditional manufacturers that use circular dot or gap to distinguish the first pin of the IC. I cannot find the information in datasheet or the topics. Anyone can give me some information? thanks very much
Hi,Why is the page-write consuming less power then a page-program? When I understand it correctly then the page-write, is first erasing the page and then writes the values back. So then the page-write power consumption should be similar to erase and ...
I am setting up SDLC communication using the Z85C30 chip. However, when I enable Tx and send data, it appears that the data is mixed with 7E. After the Tx is finished, I disable it. Is there a way to ensure that 7E appears only at the start and end?
Hello there! I am trying to get an stm8s003f3p6 to display text on an LCD1602 the LCD has the adapter board PCF8574 on it.I'm using STVD and cosmic C compiler. I used chatgpt to write the code and after quite a bit of tweaking i got it to compile and...
G'day All,Can someone please identify an ST Component marked as follows,293ST MZ2908
I'm Intermediate in Embedded C and I need to improve my code's readability, safety, scalability and portability with designing a software architecture. Can someone suggest good learning materials (books or courses) where I can learn these.
Hi, We have made a custom development board integrated with M24M01E-FMN6TP EEPROM IC. It is operating at 1.8. Having queries like whether the supply voltage plays a role in accessing total pages of EEPROM and if so please tell us the minimum voltage ...
Hello,Can someone provide me the failure rate (fit) of this Schottky diode? I'm updating our database and couldn't find this information on any datasheet / report.PN: BAT30SWFILMIf the number isn't available could someone provide a guide of how to c...
Hi, I am trying to use STUSB4500QTR in a new board. In my design, the STUSB4500QTR is supplied from a USB-C power adaptor. The application intended for use of 20V supply. When connecting the adapter to USB-C port for first time, there is 20V on outpu...
