Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
STEVAL STRKT01
Hi I am a new user, Can any please tell me which software do I need to use for STEVAl STRKT01? My aim is to transmit lora signal and received this signal on spectrum analyzer.
TIM1 registers read errata
Posted on January 09, 2017 at 10:00 So, info in reference manual is irrelevant? The read should be always done as: ; Read Seq_1 ld A, TIM1_REGH; ld XL, TIM1_REGL;�?�?�? ? Will the following sequences lead to incorrect results? ; ...
Why my STGIB15CH60TS-L has no output voltage
 When using the chip GIPS30C60-H, a 10k pull-up resistor is used to set SD/OD high and the CIN pin is directly grounded, but there is no three-phase output voltage when the correct pwm signal is input. The chip is used in a motor controller and has a...
CSLx30 by Associate
  • 808 Views
  • 0 replies
Resolved! Documentation/Path for learning STM8S
Hello community,I'm looking for materials to learn STM8S programming.I searched on the internet but I couldn't find anything. Can you recommend me any documents or links to learn, please?Thank you all!
Minh by Associate II
  • 7032 Views
  • 12 replies
  • 13 kudos
Resolved! component eletronic
Please, i would like to know datasheet about this component. Someone could help me? because i need to change this component, and i can´t find it´s in my city. 
VJM by Associate II
  • 3459 Views
  • 6 replies
  • 1 kudos
