STWPLLSim tool
Hi,I downloaded stsw-rfsol001 then run SETUP.bat file to install STWPLLSim tool.When I open STWPLLSim tool the error show in firgure below, Please fix this problem ?Thank you very much.
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Hi,I have an IC from ST where the case code is 464R. Please find the attached screenshot. Can you please help me figure out the IC's part number? I cannot find the correct information on internet. Thank you.Best regards,Adarsh
I am using STWPLLSim tool to simulate loop values for STW81200. After installing, when I start the program the following LIBRARY NOT FOUND error occurs:java.lang.UnsatisfiedLinkError: C:lProg ram Files (x86)1STMicroelectronicsISTWaLSim_v5.31Loaderlti...
Hi, I used eDesignSuite to base my Flyback Converter design with wide range input power supply and 60V-2A output. All the components look perfect to me, but the loop control with the proposed TL431 appears to be operating at about 60V. Looking in the...
Hello!Please tell me what the letter K means in the first line of the C56WK marking?My colleagues say that the ending can be either P or G. The Chinese supplier sent a photo before purchasing.We need 4 psc.Thank you!Best regards, Jack
my post is more formal than technical. Is it okay to use products that are based on GigaDevice microcontrollers? Is this company just competition, or does it violate ST patents and products with these chips should not be supported? What is ST's posit...
Hi, I have STEVAL STRKT01 and Things network outdoor gateway, both registered on Things network. Can anybody help me how can I use them in test mode. I need to change spreading factor of the steval strkt01.
Hi, could you provide :the TJmax (maximum Junction Temperature), RJA(Junction to Ambient Thermal Resistance), Rjc (Junction to Case) and Rjb (Junction to Board) for the M24128-BFMC6 EEPROM.Thanks
Hello Team,Please suggest the replacement for START499TR part.Early response is highly appreciated.Thanks and Regards,Rakshitha
我使用 X-CUBE SAEFA1 在 stm32l151 上的 STSAFE-A110 中运行身份验证例程,串口返回 6 或卡住,寻求帮助
