Resolved! M95128-DFCS6TP Thermal Resistance
I would like to inquire about the thermal resistance (θJA) of this specific part. Could you kindly provide the θJA value or direct me to the relevant technical documentation?M95128-DFCS6TP
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Can you provide me the junction to ambient thermal resistance (Tja) of M24C08-WDW6TP?
Hi There, I'm looking for thermal resistance Rtheta-JA ,Rtheta-JC Part M24C16-DRMN8TP/K .Kindly ,provide the details , I need this for thermal simulation. Regards, Ajay S
Dear sir,IBIS model required for "Part Number: M24M02-DWMN3TP/K" for Signal Integrity analysis. We downloaded IBIS model available in component page in ST micro website. But that IBIS model "automotive_i2c_m24xxx_ibis_models_-40_125.zip" not having f...
Hi Team, I'm having trouble with RHFPMICL1 pSpice model on OrCad pSpice simulation, I followed the instructions of the read me file for the simulation but still it sends lots of warnings such as: Though I followed the read me instructions: ...
I have copied the delay_ms function from the standard Discovery code, but I can't get it to work. It seems that it is running precise 10x too slow, so "delay_ms(100)" gives me a 1 sec delay.Can anyone explain what is wrong?/* MAIN.C file * * Copyr...
Hi, We use custom carrier board and ST33TPHF20SPI in our products. We need help with Linux driver (kernel < 6.0) and integration help. We only found instructions for Pi boards. Thanks
Hi, I followed the instructions for installing the tpm_tis_spi driver for linux. (https://www.st.com/resource/en/application_note/an5714-integrating-the-stsafetpm-trusted-platform-modules-with-linux-stmicroelectronics.pdf) I built and load the kern...
Hi, Are you able to identify the below products from their product markings? I believe they should both be the LIS344ALH but one of them is behaving strangely. The 34AH marked product is reading 1g (2.332V) in the z axis when placed flat on a desk. ...
I recently got another bluepill board (stm32f103c8t6) to replace the old board, and I could not connect to it using stlink. Using OpenOCD: Open On-Chip Debugger 0.12.0+dev-00600-g090b431b1 (2024-09-13-19:14) [https://github.com/STMicroelectronics/Ope...
