M41T93
Tehseen-javed
hi everyone,
Please confirm whether the attached pictures have the same part numbers. Furthermore, could you please explain the meanings of 7C004, 7C006, and 7C008.
BR
tehseen Javed
Peter BENSCH
Welcome @Tehseen-javed, to the community!
The order code is in the first line and is M41T93RMY6. This means that all three devices are identical.
The second and third lines do not contain any data relevant to you (place of manufacture, date code, etc.) that has nothing to do with the technical details of the device.
Does it answer your question?
/Peter
Peter BENSCH
/Peter
Tehseen-javed
Thank you for your kind attention and reply. Actually, these are embedded on three different controller boards: 100kVA (7C004), 30kVA (7C008), and 10kVA (7C006). That's why I was concerned about this.
