Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
M24128-BRMN6P Thermal Information
Hi,We are currently assessing the use of the M24128-BRMN6P on our prototype and the following thermal information (that is not available in the datasheet) will be useful for our thermal analysis:Max. Operating Junction temperature (where functionalit...
JW3 by Associate
  • 847 Views
  • 1 replies
  • 1 kudos
Access to www.arm.com web site
Hi,I have a big problem. I can not log-in to ARM.COM web site. I am receiving this suspicious message:"Your account registration has been received and is currently being processed."Where is problem ???? Can someone help me ?see image below:
JerryMC22 by Associate III
  • 1739 Views
  • 1 kudos
Resolved! avertissing with a passing argument in "C"
Hello everybody,I am currently programming on a STM32G0 for a screen with the st7567 driver.I created a function to display a text.When indicating the information on the font I have a warning from the cubeIDE compiler.in my main.c st7567_Write_Text_P...
JJoao.1 by Associate III
  • 1209 Views
  • 1 kudos
Resolved! STM8L051F3, TIM4, what do I miss to make it run
I'm a bit rusty on 8Bit MCU's, more used to STM32 but have to get that STM8 project done.I have a problem get TIM4 running, it might be I don't see the wood for all that trees.It gets compiled using SDCC and the header file is slightly adopted for th...
jgnoss by Associate III
  • 2155 Views
  • 1 kudos
ST MFU C104 diode info.
Help please!I'm unable to find any info on this diode from an old Siemens Siplus 24RCL PLC controller.  Pictures attached.The diode shorted closed.  I'm assuming because, someone hooked up the supply backwards!The only marks I've found are "ST MFU C1...
Kendog by Associate
  • 3161 Views
  • 3 kudos
