Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Resolved! Blue pill blink external LED
I used the settings and code below for a simple project: Blink an external DIP LED using the blue pill:In Pinout & Configuration:- PA5 => GPIO_Output- user label: LEDThe wire connections (like screenshot below):PA5 pin => Resistor => Long leg (anode)...
TechyAry by Associate III
  • 2172 Views
  • 8 replies
Resolved! STEVAL-DPSTPFC1
hi,I start to use STM mcu to develop power electronic circuit and software , I find the following stuff " STEVAL-DPSTPFC1 3.6 kW PFC totem pole with inrush ......."   is the best reference design to me for learning ,  would you please deliver its sch...
bobjeng by Associate
  • 555 Views
  • 3 replies
  • 1 kudos
LED with RX TX
I am using ST3232CTR with stm32f446re . I want to attach LED with either pin 13, 14 or Pin 11 , 12 of ST3232CTR. Like FTDI , if we have serial communication it will blink. But I need recommendation of schematic diagram or how to attach.   Can anyone ...
Ironman by Associate II
  • 356 Views
  • 1 replies
HFDA802 audio IC Driver requirement
Hello Team,Kindly provide reference material like startup sequence and handling HFDA802 IC.I want to use HFDA802 audio IC with controller but startup sequence and steps are not mentioned in attached datasheet.if possible kindly provide reference samp...
M24M01E-F device addressing
Hi there, For my project, I'm use an M24M01E-F I2C EPPROM. I found Four addresses (0x50, 0x51, 0x58, 0x59) with the below mentioned hardware connection were found when scanning the address for this IC. What changes are necessary to set up the I2C EEP...
Anyone tried embedd.it?
Inspired by a nice review by Jacob Beningo, I wanted to give it a try but failed right on the entry.Their web UI says my email is not confirmed and I have no clue how to confirm it. Received their "welcome" email, but no hints how to confirm the emai...
Pavel A. by Super User
  • 1047 Views
  • 5 replies
  • 2 kudos
