Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Resolved! VL53L4CD won't init
I'm trying to use a VL53L4CD with a micro.  BTW the platform.c file is wrong.  It says byte swapping is required for big-endian processors.  In reality byte swapping is required for LITTLE=endian processors.  Got past that and a number of other mista...
Wilton by Associate
  • 1553 Views
  • 1 replies
Old datasheet vb016 coil driver
Hello Im looking for an old datasheet for the coil driver used In automotive application VB016I have find some VB0xx series’s datasheet for others models of coil drivers but not mineIf anyone have it or know where I can find.. :)thanks mickael
Mika83 by Associate
  • 815 Views
  • 0 replies
PD57060
I found a conflict in the datasheet of PD57060. Or I understand it wrong. Could any of you kindly clarifying the confusion for me.In datasheet page 4, the gain is about 14.3db when the device operated at 945Mhz. In datasheet page 12, the |S21| magnit...
SiC MOSFET with multiple bondwires
Hi,I would like to know which type of this company's SiC MOSFET product has multiple bonding wires and the case can be opened by chemical etching. I would like it to be a single chip and not a module.Can anyone give me some advice on this please? Tha...
THuan.6 by Associate
  • 1177 Views
  • 0 replies
L6480 EVAL and X-NUCLEO-IHM02A1
Hello,I am planning to drive 3 Stepper motors using ST drivers. Currently, I would like to use L6470 for 2 motors and L6480 for the remaining one. I am planning to develop a test setup using following EVAL boards from ST, X-NUCLEO-IHM02A1 - Drive 2 s...
sps by Associate
  • 1149 Views
  • 0 replies
