Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Resolved! STUSB4500 IC failure in the field
Hi all, my team is experiencing some boards have failure of their STUSB4500 sink PD controller. We have not 100% determined the cause yet, but I found that our implementation is only using 0.1uF caps for the VREG 1V2 and VREG 2V7 decoupling. This is ...
nickray by Associate II
  • 525 Views
  • 4 replies
  • 1 kudos
Resolved! Need If vs Vf Data for 1N5822UB1 at -55°C
Hello everyone,I’m working with the 1N5822UB1 Schottky diode and need forward current (If) vs forward voltage (Vf) characteristics at -55°C. The datasheet only provides graphs for 25°C, 100°C, and 120°C, but my application requires performance data a...
EL2118 by Associate
  • 235 Views
  • 1 kudos
Resolved! About SMP100LC
Hi Team, It appears that the varistor turned on at a voltage lower than the value specified in the datasheet.・​Detailed V-I characteristics of the varistor・​How significant is the variation between individual varistors?・Once a varistor turns on, does...
