Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Resolved! ST33: Recommendation for Product Selection
Hello, We are considering using the ST33TPHF2XI2 for our application. The datasheet mentions two variants:ST33HTPH2X32AHE1ST33HTPH2X32AHD5Could you please recommend which device would be more suitable for a new design, considering stock availability ...
sonaliz by Associate II
  • 582 Views
  • 1 replies
  • 1 kudos
Resolved! Marking for M95040
Hi Peter, Thanks for replying, i have another need verity the marking, kindly check the photos of product below is for part# M95040-DRDW3TP/K ?   Part# M95040-DRDW3TP/K
CW2 by Associate
  • 628 Views
  • 1 replies
Resolved! Power Consumption for ST33KTPM2I
Hello STM32 Folks, I couldn't find any information regarding the power consumption of ST33KTPM2IWLBZA9. The datasheet does not talk about this.  I am hoping that someone from ST could provide information regarding the power consumption. Thanks,
TDA7566
We are working on one of our project which previously using TDA7566 IC. Can anyone suggest any pin-to-pin compatible IC for TDA7566? Are the following IC's are compatible - TDA7580, TDA7388, TDA7850? I would like to know more about the 3 pins (pin nu...
Raj23 by Associate
  • 444 Views
  • 1 replies
  • 1 kudos
L9369 reference design
L9369 Control Signals for Redundant Safety Switch-off Path From μC—Are these 4 signals be connected together?or connect ACT_OFF_LS1_A and  ACT_OFF_LS2_A  together ?    connect ACT_OFF_LS1_B and ACT_OFF_LS2_B together ?Is there reference design for Au...
haihun by Associate II
  • 373 Views
  • 1 replies
