STM32H725 SMPS issue
2025-01-21 1:52 AM
I am having and issue with a STM32H725RGV6.
After powering my board, I can see the SMPS output at 1.36V, which I have connected to the VCAP inputs.
I can also connect to the µC using the STM32CubeProgrammer.
However, after flashing a simple firmware, the SMSP output drops to 0V and I can not connect anymore. I am aware that this can be the result of an improper SMPS configuration (https://community.st.com/t5/stm32-mcus/unable-to-connect-to-stm32h7-devices/ta-p/49296). However, in my (cube generated) project am am calling
HAL_PWREx_ConfigSupply(PWR_DIRECT_SMPS_SUPPLY)
so this should be correct. Additionally, I tried to upload a program with nothing but an infinite loop in main, and the problem still occurs.
When pulling BOOT0 high, the SMSP output becomes 1.36V again and I can connect again. This makes me believe, that everything is set-up correctly hardware-wise. Otherwise, the bootloader would not run.
thank you for your help
- Labels:
STM32H7 Series
2025-01-21 3:55 AM - edited 2025-01-21 4:37 AM
Hello @BenUtzer and welcome to the community,
If you are using CubeMx to generate the code, I think you have the same issue as these threads:
Please confirm.
Please confirm.
2025-01-21 4:11 AM
Thank you very much. I can confirm that this was indeed the issue.
2025-03-05 11:49 PM
Issue fixed in CubeMx 6.14.0 (already available on ST website)
