2022-05-16 07:48 AM
Hi.
I want to make a qspi external loader for STM32H7B0VBT6 (for winbond chips)...
but this MCU has OCTOSPI instead QUADSPI...
now, my question is how to configure the settings for a quadspi chip (like w25q64) in CubeMX?! (https://www.youtube.com/watch?v=alzv6qg4lH0)
and is this the only difference between octospi and quadspi for making external loader or maybe should do anything else (like changing some code or...)?
2022-05-17 02:55 AM
Hi @SEMad ,
The answer to your question "how to configure the settings for a quadspi chip" is in the article Does OctoSPI interface support QuadSPI memories?
In the mentioned application note, you need to refer to the tables "STM32CubeMX - Configuration of OCTOSPI signals and mode" and look deeply to the provided examples.
-Amel
2022-05-16 10:28 AM
These loaders are all materially very similar.
Winbond W25Q devices are all usable via the OCTOSPI peripheral, the command structure gets a little more involved/specific. I've had them working on NUCLEO-H7A3ZG boards.
I'm not a code generator developer, I would recommend writing and testing your BSP, including Write and Erase, outside of the loader as this is far easier to test and debug.
https://github.com/cturvey/stm32extldr/blob/main/h7a3_octo_pins.txt
2022-05-17 02:55 AM
Hi @SEMad ,
-Amel
