Is there a bug in STM32Cube_FW_F4_V1.27.1 or in STM32CubeMX?
2023-02-27 11:19 AM
I'm using STM32CubeIDE 1.11.2 and STM32CubeMX Version: 6.7.0.
I have a question regarding the implementation of the SDIO SD card in 4 bit mode on a stm32F407 card
I am using the following configuration
SDIO Global interrupt, SDIO_RX and SDIO_TX DMA
SDIOCLK clock divide factor 5
Unfortunately it doesn't work. The f_mount function returns an error (Error SD card)
On the other hand if I replace SDIO_BUS_WIDE_4B by SDIO_BUS_WIDE_1B
line hsd.Init.BusWide = SDIO_BUS_WIDE_1B; as shown the program works.
2023-02-28 2:20 AM
Hello again @Abdelmalek BELLOULA
Well, after some investigation, the bug mentioned in the thread is fixed in STM32CubeMX Version 6.7.0 which you are using.
In this case, I think the problem is the compatibility between the configuration (4B) and your hardware ( SD card) since you get error SD card
2023-02-28 1:53 AM
Hello @Abdelmalek BELLOULA
Check this thread, it might be related
2023-02-28 2:20 AM
2023-02-28 10:18 AM
Thank you Sarra, I will proceed to check my hadware
2023-06-13 5:06 AM - edited 2023-11-20 8:19 AM
I installed STM32CubeMX version 6.5.0, I generated the code with STM32Cube FW_F4 V1.27.0 I get the following code
and it works well and no error in the hardware I checked everything
on the other hand with the latest version of STM32CubeMX 6.8.1, I get the following code: and my program crashes
SO ?
Is there a bug in STM32Cube_FW_F4_V1.27.1 or in STM32CubeMX for SDIO?
