Into CubeIde or CubeMX is there a way to generate a Report (for documentation) for all the MCU configuration ?
MaxC
Sarra.S
Hello @MaxC​,
Yes, you can use the CubeMX Report Generator Tool
In STM32CubeMX, select File > Generate report, the output is a pdf file that contains the project configuration report
Hope that helps!
2 REPLIES 2
Sarra.S
Hello @MaxC​,
Hope that helps!
MaxC
Thank you for the feedback.
