Into CubeIde or CubeMX is there a way to generate a Report (for documentation) for all the MCU configuration ?
‎2023-03-01 12:36 AM
‎2023-03-01 2:31 AM
Hello @MaxC​,
Yes, you can use the CubeMX Report Generator Tool
In STM32CubeMX, select File > Generate report, the output is a pdf file that contains the project configuration report
Hope that helps!
‎2023-03-01 2:31 AM
Hello @MaxC​,
Hope that helps!
‎2023-03-01 2:45 AM
Thank you for the feedback.
