2019-11-18 8:58 AM
2019-11-18 9:16 AM
It is not a BUG. Both in F3 and in G4 it is possible to use the same analog input pin for more analog peripheral.
This can help to reduce the number of pins. You can use the MCU manual to see which pins have matched that particular analog peripheral.
Andrea
2019-11-18 10:12 AM
Thank you very much! I had some trouble with CubeMX 5.4 configuring a STM32F334, ended up with going back to version 5.3...
best regards - Scotty
