ADC do not work with 1.10 after migration.
‎2022-03-21 08:24 AM
The clock "to ADC (MHz)" is grey in clock configuration. Don't see prescaler field in configuration. Plus it remove PLL **** configuration in main.c.
SystemClock_Config();
//****** This below have been remove from my last commit! *********
/* Configure the peripherals common clocks */
PeriphCommonClock_Config();
//****** And this:
* @brief Peripherals Common Clock Configuration
* @retval None
void PeriphCommonClock_Config(void)
RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
/** Initializes the peripherals clock
PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_ADC;
PeriphClkInitStruct.PLL2.PLL2M = 4;
PeriphClkInitStruct.PLL2.PLL2N = 9;
PeriphClkInitStruct.PLL2.PLL2P = 2;
PeriphClkInitStruct.PLL2.PLL2Q = 2;
PeriphClkInitStruct.PLL2.PLL2R = 2;
PeriphClkInitStruct.PLL2.PLL2RGE = RCC_PLL2VCIRANGE_3;
PeriphClkInitStruct.PLL2.PLL2VCOSEL = RCC_PLL2VCOMEDIUM;
PeriphClkInitStruct.PLL2.PLL2FRACN = 3072;
PeriphClkInitStruct.AdcClockSelection = RCC_ADCCLKSOURCE_PLL2;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK)
Error_Handler();
What is the workaround?
ADC
Bug-report
STM32CubeMX
STM32H7 Series
‎2022-03-21 04:51 PM
Attaching an IOC that replicates the problem would be helpful. Might be a bug, might be some other explanation.
Which ADC? Which chip?
‎2022-03-21 06:17 PM
‎2022-03-21 06:35 PM
I just started a project from scratch with STM32H750VBTx, I haven't been able to activate ADC clock yet. Pretty easy to reproduce...
‎2022-03-23 07:14 AM
Hi @GerHebert​ ,
This seems to be the same issue as reported in the following 2 questions:
- ADC not working after migration to CubeIDE v1.9.0 and SDK v1.10.0
- STM32H755ZI-Q CubeMX Does not generate ADC clocks
Internal ticket number: 124251 (This is an internal tracking number and is not accessible or usable by customers).
@Khouloud OTHMAN​ can confirm or clarify more this issue.
-Amel
‎2022-03-24 03:09 AM
Hi @GerHebert​ ,
You're right, the issue is reproduced and confirmed.
Actually, a regression was detected with the latest STM32CubeMX 6.5.0 version: Clock Prescaler parameter removal from the GUI and the non-activation of ADC Clock Mux although the ADC is configured.
As mentioned by @Amel NASRI​ , this misbehavior was already reported internally to be fixed as soon as possible.
I'll keep you posted with the updates.
Sorry for any inconvenience that this may cause.
Khouloud.
‎2022-04-01 07:43 AM
I have the same issue. Is there an ETA for this fix?
‎2022-04-01 07:48 AM
Historically, it has been several months between CubeMX releases, and one just came out recently.
‎2022-04-21 07:54 AM
36 days have passed and this is still broken, wow. I just spent two days trying to figure out why my project is suddenly broken.
For anyone wondering: downgrade to version 1.7.0. You have to change you ioc file version though:
‎2022-06-12 06:33 PM
I just came across this problem... Any idea when a fix will be released?
