How To Play Digitally Generated Sine Wave
Nhyrane
I just finish a TouchGFX code to generate an adjustable sine wave. I am planning to make 3 of them to mix them and play chords but there is a problem: how can i play a function that generated in STM32 on the speakers of that STM32?
I would be so glad to any help from you all.
@Nhyrane wrote:
I work with STM32F746G-Disco board. It has stereo output (two jacks). I just want to direct my signal to stereo but I don't know how to do it.
In that case, you need to use the audio codec on the board.
And its BSP driver from the link:
https://github.com/STMicroelectronics/32f746gdiscovery-bsp/blob/64c20f758a907cd873e368502cf16e498934d0ec/stm32746g_discovery_audio.c
And refer to the audio example:
https://github.com/STMicroelectronics/STM32CubeF7/tree/master/Projects/STM32746G-Discovery/Applications/Audio/Audio_playback_and_record
PS: Be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help/support.
6 REPLIES 6
PWM ?
DAC ?
A speaker would likely also require an amplifier/driver of some sort ...
Guru
Broadly speaking, you would send them to the speaker. Does your board have a speaker? What hardware are you working with?
Remember that we can't read your mind, or see what's on your desk - that's why it's important to include these details in your post:
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
So, from the User Manual, you'll know that they are connected to the external Audio DAC & Amplifier:
Thanks for your time and patience. That was my very first blog post but i will take account of your advice. Thanks again for guidance. Have a nice one.
